Discuss LED power supply blowing LED controller in the UK Electrical Forum area at ElectriciansForums.net
Are you sure you hadn't had your multimeter connected to it in ammeter mode on the previous occasion?
Just wondered if you had tried measuring the output current after the controller and damaged it.
With the PSU on but no LED light controller attached ,
get the multimeter set to volts DC and measure if the power supply goes over 18V between terminals 5 & 6.
This is a no load test , and may be how delicate electronics,that may only need 3A come to an end on a 15A supply .
( some 3A or 5A fuses may reduce the chance of mishaps with thin wiring on DC 12V-18V )
Reply to LED power supply blowing LED controller in the UK Electrical Forum area at ElectriciansForums.net
Hi there, Please can I have some help with the following: I want to have some perimeter lighting in the ceiling which will be using the...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
90s house electric issues continues 🥲 So after getting some good advice here I've managed to sort out some of the heating issues so thank you...
I am trying to put some led light strips under the fenders of my fat tire E-bike. I’ve been looking at led light strips on Amazon, AliExpress and...
Hello, I am currently DIY upgrading a caravan with my girlfriend but need some advice. The (very old) 230VAC to 13.8VDC power supply broke down...
