Discuss LED STRIP MOUNTING UNDER OUTDOOR STEP TREAD in the Lighting Forum area at ElectriciansForums.net
Needing to mount some weather proof led strip lighting under the tread of some outdoor floating steps and need some advice of best product method if anyone already done this sort of lighting.
I’ve put some Phillips Hue strip under a stone paving slab. It’s fixed using supplied plastic clips. But the strip doesn’t really support itself. What sort of step are you installing onto?
Not yet in place so will need to confirm with builder as to what kind of stone tops but will have large overhang to give appearance of floating steps
Use some aluminium extrusion imo.
Thanks for that.
Have tried this on a couple of previous jobs and proved very awkward when trying to fit under step tread especially with no room to drill fixings.
Thought about extrusion for led tape but with a flat piece to fit under stone flag of step as its laid but cannot source any.
Thanks for that.
Angled extrusion?
Reply to LED STRIP MOUNTING UNDER OUTDOOR STEP TREAD in the Lighting Forum area at ElectriciansForums.net
Hi everyone I’m after some advice please. I’m installing some LED profile around a customers bedroom ceiling for some led strip to sit in and...
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
Hi everyone, I would like to use LED chips for DIY projects, to power them I would start from 12V drivers for LED strips. For some chips it is...
I made a DIY light fixture by putting some cut-to-size LED strips in an aluminum housing connecting them to a Mean Well DC power supply with a...
Hi all, I'm looking at putting some warm white LED strip (3000k) in aluminium profile under some kitchen cabinets, so just looking for...
