HappyHippyDad
Supporter
Hello all..
2 years ago I fitted a solar panel to my shed, charge controller and battery. It has all been working fine, but recently it has been losing it's charge very quickly and the charge controller kicks in and turns the lights off.
The battery charges up to 13.7V but drops to 12.1V very quickly with only a small amount of power being used.
It is not a sealed battery, however I do not know how to determine if it needs topping up with distilled water? Also, what level do I fill it up to and also is this going to help with the discharge problem or is it beyond repair? I have not topped it up since fitting it.
I have attached a photo showing inside the battery, no fluid is visible.battery.jpg
I’d try topping up with distilled water. Check for damage to the cells, easier said than done but bulging of the plates visible through the holes, battery case bulging out etc.
As long as the water is above the plates it will work.
Hello all..
I have attached a photo showing inside the battery, no fluid is visible.View attachment 43711
Discharge the battery completely and then fill up with battery acid and recharge, as long as the battery ain't completely knackered it should be OK.
So the fact I can see the plates is not a good thing then?:oops:
you should be able to see the plates. but the water level should be above the top of the plates. if they are not buckled you might be OK with topping up.
As Tel mentioned the water/acid level should be just above the plates (if your wife walks up to you with a small plastic bottle in her hand then run, fast in the opposite direction)
Do you have a car battery charger as once you fill the battery with distilled water you could try to recharge it fully as most modern battery charge will try to recondition the battery by draining it then charging it fully before reconnecting it back in the shed, the old style batteries always needed to be checked to see if the fluid level hadn't dropped. Modern ones are sealed.
Hi bud...that battery looks older than me mum...what is the date of manufacture? A Decent brand will have a first use date and it should be easy enough to establish it's current state,with a controlled discharge test,from a full charge.
A vented battery like that should have its electrolyte level checked every few weeks / month if it is constantly on charge or being cycled. The rate at which it loses water depends critically on the float voltage and temperature. Optimum performance requires the correct acid concentration - as the water is driven off it gets more concentrated for a given state of charge, so the level should be maintained at the mark, often 8-10mm above the plates. Damage begins to occur as soon as parts of the plates are out of the electrolyte. Take care (e.g. eye protection) when adding water, if the acid is very concentrated it may fizz and bubble.
You could top up with distilled water, easiest and OK to test whether the battery is still usable (it might not be). This assumes all the acid is still present. Pete's suggestion to discharge, refill with acid and then recharge is what a battery shop would do in the old days to give it the best chance, as it ensures the concentration is correct. But I wouldn't personally go to those lengths as the plates might be useless already.
When a lead-acid is worn-out or damaged, it usually behaves much like a smaller battery in reasonable condition. The voltages will still look correct but the charge capacity will be a fraction of what it should be.
Thankyou lucien for that detailed and interesting reply. I have topped it up with Distilled water and will let it charge for a few days (solar panel) before using it. I cant see any mark to show what level to fill it to though. I have filled it just above the plates. In total I had to put in 1/3L of distilled water.
