Discuss Lewden Control Gear Direct no longer manufactured? in the Electrical Tools and Products area at ElectriciansForums.net
Richard Burns
Mentor
I have just heard that Lewden / Control Gear Direct have stopped producing their circuit protective devices as of 13th May, is this anything anyone else has heard of or can confirm?
I have used a fair number of their consumer units and RCBOs and will be nonplussed if I now have to tell customers I cannot get parts for them.
Presumably stock will be available for a while but it will be a nuisance if it is correct.
I would be a bit annoyed too. Where did this info come from Richard ?
I would be surprised to be honest as they have just spent the last couple of years rebranding it all, making it widely available, and bringing out spd ranges for the 18th edition. Wholesalers have been talking about new populated rcbo CU deals lately too.
Actually.... Just to add to this... Ordered a control gear switch fuse from denmans today, just opened box and its branded lewden... So perhaps they are phasing out the old branding after all.
Yep
I was told in the wholesalers that they had tried to get some Lewden breakers and been informed they were stopping production.
just emailed Lewden and got a really quick reply which was nice, the control gear site got closed as they merged head office into Lewden's in Braintree, and all control gear branded stuff will remain available at Denmans
I assume that the wholesaler heard "head office closing down" and assumed the worst. Thanks for following up. I think most of the stuff I have is now Lewden branded. Luckily the manufacturer does permit mixing of their own breakers, probably.
And breathe....
Old thread but an update. The old Lewden Mcb’s have been replaced with a new design that does not fit the old design. The buzz bar termination is approx 5 mm further back so in order to fit you would have to bend the buzz bar.
denmans have informed me theyhave some old stock left but once they are gone there Gone.
Really annoying.
I needed a C20 mcb and non of the older design was available.
the board I needed the mcb for is only 2 years old. Do have to swap the board. Ridiculous. Surely Lewden need to carry on producing parts for several years after selling the boards for such instances as this. Car manufacturers do this with discontinues ranges of car.
According to lewden… they stopped the Range CGD with a target logo printed. They still manufacturer devices under their name Lewden. It will fit in to the existing fsbbut with a slight modification. CGD fuse box busbar had wider finger than the new fsb. So to be able to use new devices you may have to file about 2 to 3 mm of the busbar finger.
Hope this will help you
I think it's just the control gear side. Lewden are still manufacturing and have released a miniature SN RCBO recently.
Might be worth emailing Lewden and asking for a declaration letter to say that they are happy installing CG and Lewden branding devices in the same enclosure.
Yes lewden is very happy to use lewden brand with cgd….they bought out CGD….. So won't jeopardize their future business… the technical also confirmed that busbar fingers on CGD may be bit wider so taking 1 or 2 mm off to slide the new version
Have they confirmed that in writing? In particular that they comply for type testing purposes to BS EN 61439-3 so that 16kA pfc can be used?
I'm trying to get a list together of ones that are confirmed as compatible so would be useful to see how they word it.
not entirely happy to go shaving a busbar, even by 1/2mm without very clearly manufacturers instructions that it doesn't compromise anything...
I agree… one shouldn't have to modify the busbar… since technical confirmed that CGD was marketed by lewden and lewden bought out them… it is in lewden interest not to shske the boat. Ask them the questions ?they will explain
Afaik its now identical bar the stickering, even has the lewden address printed on each conponent, and if you buy the spds for the control gear boards your given a kewden branded one.
Reply to Lewden Control Gear Direct no longer manufactured? in the Electrical Tools and Products area at ElectriciansForums.net
Hello all.. I'm quoting for some work and would like change the type AC RCBO to a type A. Consumer unit is a castlec which I have not come...
I was carrying out an EICR today. The consumer unit was a Control gear direct board. It had one chint MCB in it which had been put in recently. It...
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
So this Sunday coming, 3pm, the mobile phone networks in the UK will allow the government to send an alarm signal to every compatible device in...
  • Locked
5K
