Discuss Light Fixture and Fire Alarm question please in the UK Electrical Forum area at ElectriciansForums.net
vanessap
Hi All,
Please may I ask if light fixtures must now always be fitted by an electrician?
also for domestic homes, is it okay for there to be a battery operated fire alarm and carbon monoxide alarm or should there also be a heat alarm and all three hard wired in?
Thank you all so much,
Vanessa
Re your first question: no (but competency and ability to fit correctly is important)
Re your second question: It depends, but where I live, in Scotland, you would typically have smoke alarms in designated areas, heat alarms in designated areas and CO alarms in designated areas. They do not require to be hard-wired, but the smoke and heat alarms must then be linked by a radio-module and be powered by a 10 year lithium ion battery. Currently, CO alarms do not require to be linked to the others, but if battery-powered they also need to have 10 year batteries to meet current Scottish regs.
A somewhat truncated answer as there are many things to consider, but actually there are many sources of information on the smoke/heat/CO alarm scenario available online, and reading some of those will certainly assist you.
Thank you so much @pirate
Still have to be hardwired here (obviously with battery backup).
Reply to Light Fixture and Fire Alarm question please in the UK Electrical Forum area at ElectriciansForums.net
Hi all, i'm just after a definitive answer regarding a fire alarm system in a communal area/stairwell. There are call points, smoke heads &...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Hi all! This weekend we have an offer on 8 of our most popular Smoke, Heat & CO alarms from trusted brands! Don't wait too long as these offers...
Does anyone know what the new rules for England are for the rented sector smoke alarms and carbon monoxide detectors? Can they be battery powered...
I currently have a home with 7 interconnected, hard-wired smoke detectors. I have a hard-wired heat alarm in the garage that I need to have...
