E
electricalrob
Hi there don't know if anyone can help. but I had a strange lighting fault none of the lights where working but 240v coming out of the mcb so I checked the first fitting and it was saying there was only 12v there and every fitting I checked had this. there are no transformers on the circuit so im a bit baffled going back monday to check every leg of the circuit. Lights do come on but only one will and if you put a second on the first one goes off.
Cheers
Rob
Cheers
Rob
