Discuss Load and Supply 45 Amp DP Shower Switch in the Australia area at ElectriciansForums.net
C
Colin Derick
I have recently moved a 45amp DP shower switch to a more convenient place but when I disconnected the cables I forgot to take note of which cable went to the load and supply... when I reconnect the cable does it matter which one I connected to? What will happen if it's connected the wrong way? How can I identify which cable is the Load and which is the Supply.
Regards
Col
It only realy maters if the switch has a neon in it.
Then you would soon know if you connected it incorectly because the neon would be on permantly.
Reply to Load and Supply 45 Amp DP Shower Switch in the Australia area at ElectriciansForums.net
when installing circuits protected my mcb's , i have always used the 80% rule. eg a lighting circuits where the load won't exceed 80% of the mcb...
I have a loading arm on a vehicle powered by a hydraulic motor powered by a 12 volt motor. The motor is initiated by proximity switches on the...
Hi, The wiring for my lights have multiple COM wires in most rooms, which are a pain to screw into the COM part of the switch. The switches that...
Currently, I have a side garage port (with a garage door, but open on the garden side) supplied by a 2.5mm2 radial circuit. The plan is to convert...
Hi guys I was recently ask by a customer if/how his house could be supplied by his electric car. He wants to charge the car at night on low rate...
