Discuss Looking for a piece of kit in the Industrial Electricians' Talk area at ElectriciansForums.net
W
wattsup
Jeez I get some enquiries lately...
I need to price for a warning bell when demand exceeds 60amps ac.
I guess I would need to wire an ammeter, which somehow sends a signal to a relay which in turn would trigger the bell. Is there such a thing available, how do you search for such a device? Or will it need to be made to order?
I've found a wireless device where a couple of magnet type thingies fit arround supply cable, but it just gives a remote visual on current drawn and I guess it wouldn't work if transmitting through several walls.
What would the device be called ? Anyone any ideas for search queries
Current sensing relay. Run the conductor being monitored through the "doughnut" on the relay. I used one of these recently to turn on a beacon when a conveyor motor was running:
AC Current Sensing Relay
RS should do something.
There are panel mounting ammeters with high/low relay points. Or there are pump monitors for over-current or under-current, which are a bit like the thing MDSHUNK suggested.
Thanks guys,
md I like that piece of kit, exactly what I'm looking for, all bundled together nicely. Can I connect 230v?. Without emailing them I can't find a price either.
Reply to Looking for a piece of kit in the Industrial Electricians' Talk area at ElectriciansForums.net
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
R
As an electrician, how often do you get jobs from homeowners to add a 2nd light switch into an existing lighting circuit? Having recently...
S
Hi all, I am building a portable workstation to hold 4 power tools IE: Router, Saw, Disc sander (Drill powered), Small Drill Press. The idea I...
E
If you want to save on your monthly electric bill and reduce your greenhouse gas emissions at the same time, you might buy a new, energy-efficient...
Electricity News --
E
S
Hi, Id like to install burglar alarm and CCTV in my home, and was hoping someone could spec me a decent quality setup, at a reasonable budget...
