A second floor flat, hi spec decoration and finishes, and the incoming water supply (in copper) is on the other side of the flat from the CU which is to be replaced. There is currently no main bonding, but the gas will be relatively straightforward.
The floors are all done in hardwood, the ceilings have original plaster coving. An upgraded CU is going to be a significant improvement even without the water incomer being bonded, but.......!
What would you do?
What would you do?
