Discuss Main Earth Regs in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
L
LC2
Hi all new to this forum site and a fairly green sparky. Need a bit of advice hope some1 can help, OK got stacked consumer units to change (main one and an economy 7 smaller one) main earth from supply side only goes to main consumer unit (16mm) and then a 10mm is just dropped down from main unit to smaller one but they both have sepertate meter tails. Please can anyone tell me if this meets 17th regs as i cannot seem to find it in there anywhere. I beleive that i should chenge the 10mm to 16mm but still do not know if linking the consumer units like this is OK. Or does the smaller unit need it's own main earth from supply side. Helppppppp. I am aware that i could put it all on one unit with seperate main switches but job is to just change them as they are.
Hi and welcome to the forums.
As a rule if a DB has seperate meter tails, then I would install a seperate earth aswell.
Cheers.
Agree with Leonard.
16mm main earth from cutout to MET. 16mm from MET to each CU.
Dont forget this work would also need notifying under Part P of the building regs.
Reply to Main Earth Regs in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Morning guys! Went to look at a consumer unit change today with a PME supply. Now, right next to this was an old BS3036 60A fused mem cutout...
