Discuss Mains box to Consumer unit SWA or tails? in the UK Electrical Forum area at ElectriciansForums.net
Terminate the SWA into a metal flush box behind the CU
Yes,as I explained (and you later posted pictures of yours) that is exactly what I have done on many occasions
I never terminate swa without a shroud,having said that,we never used to fit any sort of shroud on Pildwa cable, so other than corrosion and maybe looking better,your later statement about not fitting shrouds had me scratching my head for a good reason to disagree
My last thought about not using a shroud is that Pyro always looks abysmal if it does not have one
Presumably you are talking about sheathed pyro?
That is where it started on that job, it was all bare pyro apart from the SWA submain, so to keep it consistent with the brass pyro glands and bare copper cable I didn't fit a shroud on the brass SWA gland.
That's why I never take photos of any of my work (not that any of it is worth photographing), certainly not post them here to get ripped to shreds. But it just goes to show that even ardent professionals can get things wrong. While we're on that subject, where's the core identification of the grey & black cables, and cable not terminated and those terminal screws aren't aligned.
Absolutely shocking :). Now NO FFO
I often take photos as a record of what I've done and as a reference for future jobs. I have no issue with my work being criticised here, I could learn something.
What you can't see so well is that there isn't even a service cable, cutout and meter in the box yet, it's just not good enough in my opinion.
HI all,
usually take tails form a MEB box to consumer unit no matter what the length as long as i can get the 50mm depth, builder has told me he wants it in SWA, ive told him its pretty much impossible to terminate it right if i use SWA also i run up the cavity with the tails and there is no way i can get SWA up there so will have to run inside up the wall which i hate doing, what do you guys do if using SWA??
Cheers
Grand
Nonsense opening statement/comment and then 4 pages!
I was joshing with you davesparks. I praise anyone posting pics of their work. I wouldn't. :)
I think you would have to install a switchfuse in the meter box regardless of the length, otherwise you'd be relying on the company fuse to provide the protection.
yes , i usually fit a KMF as i run the tails, new builder who seems to know more than most as usually you can tell them anything to make your life easy with the install, but he seems to know quite alot about the regs as we were going round the property. ill probably be able to do it in tails when i explained the ball ache of installing SWA.
Cheers
Grand
Cheers
Grand
You should be telling him, he's only qualified to lay bricks one on top of other :)
Cheers
Grand
What ball ache is there with installing SWA? I've never yet had any problem getting them through a house when a submain is required, it's not like it's ever anything particularly big.
I certainly wouldn't be using insulated and sheathed tails as a cable for a submain, that smells a lot like a lash up to me.
The last SWA submain I installed in a house between a garage and an internal cupboard where the CU was sited was a real pain, used 25mm 3 core and it was like an iron bar and very inflexible, for some reason it's trickier at that size than it was years ago, unless I'm getting old and weak. :)
25mm seems quite large for a domestic supply, the last one I did was a 63A supply on 10mm for a three bed house.
Yes I'm sure 16mm would have been fine Dave [12m run and also partly under an insulated floor] but it was an all electric property and I just happened to have enough 25mm left over from another job. So I made it hard work for myself really. :)
That's makes sense, use up the offcuts, otherwise you end up like me with a shed full of offcuts which might come in handy one day but you never use.
Might have been LS0H it's a biatch to strip
Erm no comment. :D It would be a long journey for me Dave for the sake of one bag of copper. No I meant been there as in the same situation as you well know. :)
Reply to Mains box to Consumer unit SWA or tails? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Customer has an extension and this compromises existing meter position, DNO is extending incomer and putting meter box on a different...
Hi everyone, A diversity question concerning 2 consumer units fed from 100amp DNO supply Background, So I have an 18th Ed compliant consumer...
TNC-S main supply with 16mm swa supplying garage consumer unit from main consumer unit in house, then 4mm swa supplying pond equipment through...
Just wanted to know which people use. My case. Client converting attached garage into new rooms. Consumer Unit has to move to accomodate this...
