B
britishguy4
Hi Guys
We're having work done to insert an open plan kitchen-diner and snug seating area plus wood burner into already existing extension. One load bearing wall is being knocked through.
Electrician just bumped his quote up by £820 to cover replacing this consumer unit and moving it up the wall (above where the fridge will be going), breakdown:
Consumer unit replacement (even though no new circuits) = £500
Plus he's said we need new mains wired:
2 x smoke detectors (top and bottom of stairs in main house, not even area we're having work done) @ £80 each = £160
1 x heat detector in new kitchen = £80
1 x carbon monoxide detector in new snug area = £80
House built in 1982 and has one battery operated smoke detector at bottom of stairs.
1. Are these mains powered devices necessary as we'd be more than happy with the long life 10 yr battery powered devices?
2. Is it necessary to replace and test etc. the original consumer unit (photo below)?
On the face of it there's no requirement to swap out a perfectly good distribution board. It may not be the very latest but is still fit for purpose and a very good make.
As for smokes/heat/Co detectors etc as I'm guessing yours is a private property then there's no requirement for mains powered devices although they are my preferred option.
Has the electrician mentioned membership of any scheme such as NICEIC/STROMA/NAPIT etc?
I would seek quotes from another two electricians, if you know anyone that could recommend one then great if not post up a rough location then I'm sure a forum member would be close by and able to quote for you.
open that cover of the consumer unit ,so we can see if it justifies that price ,was their any testing done .
love when the ops put location uk ,their has well put the moon ,where I'm on .;)
  • Funny
Reactions: DPG
You’ll need a Carbon Monoxide alarm for your new wood burner.
Thanks Strima, appreciate the reply. Electrician hasn't mentioned any schemes.
I'm in Selby area, North Yorkshire. As a new member to the forum I didn't really know how local to put my location so will update. Also, yes, private property, thanks.
That's the original consumer unit, installed prior to us purchasing the property.
As a new member I didn't know how local to put my location, as a bit of sound advice you could have replied in a friendlier manner to say that providing a local location would allow for local quotes etc. Thanks.
  • Agree
Reactions: custie86
death by fire or sleep and you will not wake up, you choose .
You don’t have to have mains wired interlinked alarms, as already stated.
However, as you are having building work down, with building control involvement? Do they have any stipulations, I had to go for mains powered ones a few years back with my extension.
Thanks Midwest
Yes, I should have said in the OP, building control will be involved, sorry about that. I've just called building control to check and they ummed and arred a bit before saying mains wired would not be required, didn't fill me with confidence to be honest.
  • Funny
Reactions: DPG
You'll get used to Buzz, don't worry :)
Cheers, you're just trolling now
no ,trying to help you ,if you having any work done then the only people to give you advise this your local building control .
Take Buzz with a pinch of salt, he's often out on day release and sometimes he manages to avoid his carer and gets online.
I have slipped the net again .
  • Funny
Reactions: DPG and Strima
Thanks everyone.
Just had a chat with electrician and explained what building control said about not needing mains powered sensors. He's said to check with main builder and the building inspector, so will do that.
He also says because the consumer unit is being moved it needs to adhere to updated regs, so we need a new "gen-18 unit" and "these are a bit more pricey than they used to be". - Can anyone confirm if this is the case?
Losing the will a bit here, phew.
Hmmm. How far is CU moving, and are any of the circuits being extended?
CU is moving about 6ft up the wall it's currently fixed to, mains cable runs up the same wall.
We've not anticipated any circuits being extended as the current rooms already have lights, sockets, oven etc. circuits in them. There will be some moving of wiring but doubt there'll be additional circuits needed. There are 3 spare module slots in the current CU if that makes any difference.
Thanks everyone.
I'm glad you will sort it out ,I can now take the pop corn out of the oven .:D
IMO then is just moving an enclosure & I would suggest comes under maintenance, & does not warrant latest. In such a scenario, I would contact my Scheme for guidance, but as I'm no longer in a Scheme I can't.
Buzz - I know you're just messing mate but is there any chance you could answer the questions I've asked and genuinely give your expert view on this situation
I put that in post #15 for you .
its about time the government need to put on tv about part p, so people like you ,would under stand how things work ,your building inspector and builder should advised you straight away .and the spark that doing the job .
Reactions: custie86
that is total Bollox. re-siting a perfectly good CU is compliant.
a "gen 18 unit " is just the same gubbins in a metal box.
If the CU is being moved 6ft up the wall, its not going to be at a regulation height, ie it'll be too near the ceiling. You'll need steps to reset a breaker.
Nothing wrong with using battery powered smokes with radiolink interconnect from Aico for example. More expensive to buy, but saving time on install. (4 detectors, 30 minutes tops) and theres no cables to run under floors etc. No damage to existing decoration.
The only thing not regulation with the board is that its plastic. Buy a metal one yourself and use the existing breakers. Just has to be the same make of board.
Is this electrician already doing work for you or is there a chance of getting other quotes?
Reactions: pirate
regulation height for CUs ( along with dwarf accessible light switches) applies ony to new builds.
Reactions: custie86
See post #11 mate. I'd already explained that I'd spoken to building control and they'd contradicted the electrician.
I can only go on what I'm told up-front so if I get an updated quote just before work starts with an unexpected extra £820 for the extra electrical work I'm well within my rights to question that. Good job I did too, eh, as if I didn't I wouldn't be here getting good advice from people who know a bit more than I do.
What I've worked out today is that there is a disconnect between electrician and the builder and inspector. I'll find out tomorrow morning exactly what the building inspector expectations are in terms of mains wired sensors.
Your comments throughout have added nothing of value but the guy trying to get the advice got it from those that would rather be helpful. Sorry if you've taken some kind of offence early on in this thread, I'm only asking questions mate....
  • Agree
  • Friendly
Reactions: custie86 and _ross
take no notice of buzz. he's a train wreck when sober. gets lucid after a bottle or 2 of Jack Daniels. :D:D:D.
A bit of banter can keep the mood of the forum nice and light. Don't worry about it. We generally manage a 25/75 split of useless/useful so not too bad :)
Thanks littlespark
The main builder has got his preferred electrician, I've just spoken to him (builder) and explained I'm not happy with the extra £820 and want him to check with building inspector before any of the extra sensor related stuff is started. Apparently building inspector won't be getting involved in the CU debate, it's down to the electrician's governing body so that's thrown up another question?
Hi - there would seem little point in replacing that Consumer Unit. But they are not that expensive. If it's being relocated it will involve the same testing IMHO as replacing so you could consider it I suppose. I'd confirm the brand and type of detectors planned, as there are £10 ones and £60 ones, just saying.
As I said before, nothing wrong with that board, it's a better quality one than they would more than likely install and there's no need to update as it's only being moved. Not as if it's an old 3036 board.
  • Agree
Reactions: telectrix
What are the schemes take on 'moving' a consumer unit?
It will involve the same work as replacing old for new, so should involve the same testing of cables and connections.
If it was just moving a couple of inches to fit in another piece of equipment, then no disconnection taking place, no need to update board or test.
Its this individual electrician's understanding of the regs.
Reactions: britishguy4
So all the guys on here stating they would not change the board what certificate would you provide?
Because you wouldn’t be able to provide an installation certificate
For the cost of a new easy 9 board without breakers it is a no brainier
The smokes he is rong but you can’t beat hard wired for reliability what price on your family’s life
From my experience on the few extensions, I have been involved with building control have wanted smoke detectors on the escape route and heat detectors in the kitchen.
Mini-update-
From tomorrow, 1st March, the regulations change in Scotland, allowing the fitting of 10 year tamper-proof battery alarms, smoke and heat, linked by a wireless connection/radio module, in rented property, where previously hard-wired alarms were required.
  • Agree
Reactions: MG201 and DPG
Thanks for the input guys, very much appreciated. Builder has said he's checked with building inspector and the inspector wants to see minimum 2 x mains wired smokes. The heat and CO he's not bothered about apparently. Weird!
The cost associated with moving the Consumer unit is at the interpretation of the electrician based on his governing body and he's not changing his mind on that. He still says we need a new gen-18 metal box.
Sounds like building inspectors have there own interpretations as I'd been given advice from LA building control that wired mains detectors weren't required. The builder is using a private building inspector company.
Mains wired smoke / heat / CO detector question
britishguy4,
MG201,
