Discuss megger 1552 sine wave symbol in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
If i remember correctly , this is what my megger used to show when it went up s""t creek ?
Each time was followed by a rather expensive repair and get this ! The need to pay for a recalibration as megger would not do it at the same time as the repair ???
It happened 3 times in one year about 5 years ago and thats when i went for a top line fluke and touch wood to date !!!
This type of behaviour is typical of a faulty Megger MFT continually displaying the hot warning symbol, when Hi-current loop testing, despite ensuring the MFT has cooled down between tests. Usually caused by a loop load that has reduced in value outside the manufactured tolerance and is being 'cooked'.
The hot warning symbol is a 'thermometer' seen at the top of the display on the far right hand side, on a Megger MFT15xx.
Because the repair of this type of fault requires the replacement of a number of components parts the instrument inevitably requires adjustment and re-calibration to ensure its intended accuracy is brought within the manufacturer's original specification.
Hi Telectrix , i know it has taken about 8 months but here it is !
It has been in a flight case on a shelf in the stores for the last 6 years or so after it played up last time .
Reply to megger 1552 sine wave symbol in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I know how I was taught to test a RCD, 6 tests in all two no go, two under 300 mS and 2 under 40 mS with no load. But thinking about it not so...
Please help, I'm still new to testing for myself and sometimes I wonder if my new Megger is being naughty on purpose as my Fluke wasn't as prone...
5K
M
Hi, Borrowed someones megger 1552 today to megger an alternator @ 1kv and check windings. now keeps showing battery symbol on IR test It was...
MacLec
M
S
Hi tried to do a Zs at a house today and my meter displayed "fus" NEVER seen this before. Not in the manual. Not the fuse symbol...
SPARTYKUS
S
R
Hello all, I am after some advice, I have just bought a megger 1552 tester. I was "practicing" with it today as I am a novice when it come to...
13K
