P
p11jor
Hi all just thinking when doing a rewire and running the cables down into the meter cupboard then these are never within the 150mm from edge, tomorow I am going to put metal capping over these, how do I connect a earth to this steel? Should I just run a 4mm from the earth block below?
Capping does not provide mechanical protection once it is plastered over. It is only used to stop the cables being damaged by the plasterers trowel! You could drill straight through capping and you wouldn't even notice. You install it with nails!
Isn't it in the regs though if your cable is not 150 from the edges or running inline with sockets and switches horizontal or vertical then steel earthed protection must be used?
I will have to check when I get my regs out.
Yes but the preferred methods of achieving this are by using, steel conduit, steel trunking, or a steel plate. I beleive the steel plate has to be min 2mm thick. Not too sure about the last point though. IMO, if it's difficult to pierce with a drill bit, then it's ok.
Sorry that's what I was getting at! So does this have to be installed to all the incoming cables above the meter cuboard if out of the 150?
Surely they will be "Clipped Direct" therefore visible and will also be protected with "Additional Protection" in the form of RCD's?
Failing that, ensure they are buried no less than 50mm in the wall :D
Or, just another suggestion, box the cables in???
No.... The consumer unit is like socket, left right up down is safe. You can see the cu! If you THEN find someone has drilled directly below above left right of it, well..... They're very very silly ....
Re plastered over - I agree with above so long as the tails are still visable why would that be a problem?
Metal capping outside the 150
Australia
p11jor,
SirKit Breaker,
