Discuss Metrel MD9272 Leakage testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi,
My new leakage tester arrived so I wanted to try it out, I connected it to the Line and Neutral meter tails and got a total leakage with all circuits on of 8.05 ma, I turned them all off and re-tested individually and found that the first floor ring final was giving the highest leakage of 6.34 ma
I wanted to see how this result compared to an RCD ramp test so I turned all circuits off and connected direct to the RCD and it tripped at 24ma, I turned the ring final circuit back on and re-tested and to my surprise I got the same result of 24ma??? Indicating that I have no leakage which is not true.
The tester is a Fluke 1653 which is not long back from being calibrated.
BTW: The new Metrel 9272 is a fantastic bit of kit and I cant wait to use it fully.
Any ideas?
Reply to Metrel MD9272 Leakage testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
I just finished a garden room supply. The customer already had a CPN garage consumer unit that the last sparks left there, brand new in box, and...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
