Discuss Mk Sentry CU Main breaker positioning in the UK Electrical Forum area at ElectriciansForums.net
L
leitrim99
Can a Mk Sentry CU Main Braker Switch be positioned to the right of the Cu as all photos I have seen of the Cu the swich is on the left Thanks
Once you start tinkering with the CU your starting to go against manufacturers design and therefore could be going outside the scope of BS 60439 UK Annex ZA.
I'm sure though MK would do some sort of conversion kit to change there boards around, have you contacted them to ask?
Will do wylex units are orientated the way i want so might use one of them
Used an MK 5+5 dual RCD board today and i wouldnt reccomend them at all, very flimsy and poorly made. No wonder wholesalers are knocking them out at £55+ vat inc MCBs.
Id rather Hager, Crabtree etc...
Couldn't agree more. I had a bit of an obstacle, climbing over customers furniture to get at the board. A bit of a long story but I was setting a temporary supply for builders tools etc. when I took off the front cover, one of the "captive" screws fell out and has disappeared into a parallel universe. The case is so thin and flimsy it was very difficult to get the cover back on. Anybody know where I might get these screws?
Reply to Mk Sentry CU Main breaker positioning in the UK Electrical Forum area at ElectriciansForums.net
Hello mates. i have an MK CU to replace. As you may know, the main switch in MKs is on the left hand side. There's no way to replace the...
I've got a dual rcd mk sentry board that I want to inverter into an rcbo board. If I link the two neutral bars from the main switch is this OK to...
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
