Discuss Need help identifying this starter motor in the Auto Electrician Forum area at ElectriciansForums.net
I do recognise that archaic inertia return spring,set-up...cannot remember what off...could be british,Austin,Wolseley,Humber,maybe.
It's used,and someone has painted the spoons,off it...
Try the forums of our collecting folk,with the Lucas number,as a search.
Unlikely it's off a car because there's no solenoid built into it. More likely a boat or tractor or truck or something commercial. Also most car starter motors had 2 ears at the front with bolt holes in them for mounting.
After a bit of digging around I might be wrong. I know it's not identical but it looks very similar to this rotax unit that went on a 1923-1924 Sunbeam....
After a bit more scratching I think we might have a winner;
Actually not, the gear has a collar on it and your doesn't. Pretty damn close though....
Yeah we were thinking some sort of commercial/boat as its earth return, that 2nd picture does look awfully close to our starter but as you say the collar on the pinion is what sets it apart, i thought it wouldve been an older model than 47 - 53? either way we are getting close thank you for your help :) much appreciated.
Reply to Need help identifying this starter motor in the Auto Electrician Forum area at ElectriciansForums.net
Good evening all Ive got an old truck 1990 that has always had intermittent starting issues whilst ive owned it.. As far as i am aware the...
Hi all I have a small DC motor that I pulled off from an ABS car module and need help identifying some parts in order to hopefully rebuild it. 1...
Friend of mines dryer machine has stopped working, 2 days out of warranty. I am trying to help theme out as money is tight for them however, I'm...
We are in the process of restoring 4 of a group of 5 Brookhirst DC motor starters from 1936. These are a thing of beauty and the engineering in...
Hi Experts, I was given a Ryobi 240v Table Saw which I think came from South Africa. The motor was disconnected when I checked but I would just...
