Discuss Need help matching power supply to LED project. in the Lighting Forum area at ElectriciansForums.net
tedoro
Hello,
I am an artist in Portland Oregon and I need to power an array of 3 watt cob leds (9-12vdc 260-280ma)
They need to be strung in strands of 8 (12 total strands) 96 total leds.
I would like to run them a little underpowered to reduce the heat and make things a bit safer and perhaps last longer? I've tested them on a small constant current power supply at about 2.5 watts strung in parallel and that seems about right.
How would you design the power for this, with safety and affordability being important. I am decent at following instructions...
Many thanks, Tor
So you want 12 strings of 8 LED modules in parallel. Do you want all the strings to operate together with a single driver (power supply) or are the strings far away from each other and better suited to 3 separate drivers?
Current and wiring size becomes a big factor when you've got a total load of 250 watts at 12V, you need substantially sized conductors to carry that current if all the strings are on a single driver.
The reliability and longevity of the LED modules will be greatly affected by how you mount them and how effectively they're heatsinked by the substrate they're sitting on.
From the safety aspect I'd suggest using a good quality driver like a Meanwell and ensure your wiring sizes are appropriate for the current.
**edit. Not sure if the word 'heatsink' is a verb or not, if not apologies for the poor English..
Reply to Need help matching power supply to LED project. in the Lighting Forum area at ElectriciansForums.net
Hi there, Please can I have some help with the following: I want to have some perimeter lighting in the ceiling which will be using the...
I am trying to put some led light strips under the fenders of my fat tire E-bike. I’ve been looking at led light strips on Amazon, AliExpress and...
I am currently making a scaled model display that uses 16 LED in a series and I would like to wire it up to be on one switch, so I need a single...
I have a question for those who are well versed in electrical and lighting issues. In my neighborhood there is an elderly lady who, while she has...
Hello, I am currently DIY upgrading a caravan with my girlfriend but need some advice. The (very old) 230VAC to 13.8VDC power supply broke down...
