G
GLENNSPARK
well...What do you mean by break down box?
I have checked the continuity between supply socket and load at both sockets in question and there is continuity between all even through the FCU
it dont add up...does it Lee...
check polarity (use a loop tester to do this)...whilst you are at it get a Zpn...see what value you get...
you will/should know if its abnormally high....as you cant be 100% sure that plug in tester is OK....better to have some proper values...
