Discuss Neutral Fault in the UK Electrical Forum area at ElectriciansForums.net
Hi Lee.
I wouldnt trust your socket tester. The other day my socket tester shown me the same thing...
Turned out to be a broken cpc inside the sleeving. It all looks ok visually. Only after a continuity test did i find that out.
Always start with the basic tests.
Good luck.
and yet again the O/P does one when they are either found out to be a DIYer....
or are not competant...and have neither the necessary test gear..or the knowledge to carry out a systematic stage by stage faultfind...
lol...
I despair, I really do.
Tell me Mr. Dicks, are you a fully qualified domestic installer? If you are, send me the nice certificate you paid £1000’s for. I’ve got a paper shredder standing idle at the moment.
Reply to Neutral Fault in the UK Electrical Forum area at ElectriciansForums.net
Today I was doing an EICR and went around a couple sockets with a Megger MST220 socket tester just to see if there was anything obvious, all three...
Hi Guys, I'm having trouble diagnosing a fault on a customers downstairs socket ring, which only ever trips when the washing machine is used. The...
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
Hi All, This might be a bit of an odd question, I would really appreciate your thoughts. I am trying to up-date my mum's home, before putting it...
