Think about how an rcd operates.
It is a simple comparison between live current and neutral current.
An imbalance between those measurements of >30mA will cause it to trip.
It is not possible to give a resistance between N and E that will cause it to trip or not trip.
A fairly low resistance fault could be tolerated if there is zero load on the entire installation
As loads increase, not only on the circuit protected by rcd but also others, a combination of parallel paths and differing volt drops in parts of the installation can cause it to trip.
