• If you have electrical work available, then you are in the correct forum.
    Post details of the position you have on offer in this forum. Domestic / homeowners are also welcome to post electrical work they have available on their property. Or you're welcome to seach for a Local Electrician in our directory.
Discuss New consumer unit and partial rewire in Didcot, Oxfordshire in the Electricians Jobs area at ElectriciansForums.net
This electrician job is going for grabs, please don't post contact details in this area of the forum. Use the forum messaging system instead.
Yes I’d already seen it but again different people have different views on different things and that must be his personal opinion.
In @Murdoch defence @Sintra , when you view @jdtae profile, it looks like nothing constructive comes out of the ratings he/she give out, especially when there are a lot more negative ratings than positive.
I don't agree with banning, but the rating system could do with looking at.
Tbh the rating system has more positive than negative options. No one knows how other people are thinking at any particular time. My point to this is that we all have to respect others opinions without wanting in depth explanations.
Not against people having different opinions, it's just that the last 3 ratings (Old, Bad Spellings & Dumb) should be scrapped. Nothing good comes from them.
If I post something and someone thinks is Dumb then I'd prefer them to explain why. That way, if I'm being dumb, I will learn from it.... I learn nothing from someone just hitting the Dumb rating..
They aren't on the plumbers forum ............ so why on here @Sintra?
We have old for pete and Tel , we have bad spelling for Buzz and we have Dumb for...........
To keep people like you happy as you do seem to use the negatives quite regularly.
I doubt you've done proper research, but if and when I use them, I do quote the post and give a reason ....
I think they need to be removed.....
Why don't the plumbers have them then?
I can’t answer that question as I didn’t set up the forum software. If you feel the 3 ratings in question shouldn’t be there then don’t use them.
I've given you a dumb because these can be included or excluded - Dan could do this ................
Do you realise how ridiculous that sounds, do you honestly expect Dan to remove them just because you don't like them. As Sintra has already pointed out , if you don't like them then don't use them.
I disagree with you there mate.
If Old, Bad Spelling and Dumb could be removed then it would be a good thing.
See my post #55 for why.
I'm using the phone mate so can't see post numbers.
My point is that a member cannot hand out 79 Dumb ratings and then ask for the ratings to be removed because he got a couple, you must be aware of the saying.. Don't dish it out if you can't take it.
Tbh I’ve looked through at lot of members and what ratings they’ve given and those 3 are seldom used. The one person that sticks out that uses these 3 the most plus the disagree rating is our friend @Murdoch
@GMES @Sintra . I'm just talking from my point of view mates. I rarely give out bad ratings. As in the post above to @GMES , rather than giving a Disagree I just posted that I disagree and explained why.
Yes I have give out a few jut they are rare.
@GMES, the last 3 ratings (Old, Bad Spellings & Dumb) should be scrapped. Nothing constructive comes from them.
@Spoon I’m not disagreeing with you all that I’m trying to get over to @Murdoch is that he and one other appear to be the biggest users of these 3 ratings. If they did get removed then I have an inkling that they would use the disagree option instead. Personally I don’t use the negative ratings regularly and would prefer to critique in a reply.
In fairness to @Murdoch, there are a few low content members out there, that give 'dumbs' out, and very little else. I recall one guy give me a dumb for a very innocuous comment I made, which I challenged and he made no reply. Not surprising when he only posted about four times in 5 years!
I agree that there is an odd member like that but there wouldn’t be very many. That’s how this whole thread has gone completely off topic as someone like that pressed the dumb button on Doc.
Precisely
@Sintra .... please note that @jdtae has used the “dumb” button 31 times more that me when calculated by percentage of postings
My ratio about 0.5% .... often at @essex when he’s pulling “chains”
@jdtae about 15%
Action against him is far more sensible imho .....
Precisely
@jdtae about 15%
@Murdoch big wow some guy has used the dumb button twice and I should be taking action against him. Well do you know what that isn’t going to happen. The rating is there to be used and it’s staying there so either use it or don’t it’s entirety up to you. Either way stop moaning on about others using it.
Precisely
@jdtae about 15%
This all seems a little petty. I'd say there is a fair chance that a forum member that doesn't post a lot and doesn't give many ratings they have probably done it by accident more than anything, it's very easy on a mobile device to do that. Or they maybe meant it. Either way action against a forum member for using the rating system is a new one on me. Should they be getting bans for that then?:tearsofjoy:
And what would you do if they took the optimistic button away?:tearsofjoy:
Well according to @Murdoch the guy that dared to rate one of his posts as dumb should be deleted from the forum. There will be no action taken against anyone for giving out a rating. Give me a dumb for this and see if I care :)
Jdtae won't be getting any action taken against him just because Murdoch wants it, he however may end up with action taken against him if he carries on pushing Sintra. It reminds me of a dog trying to get through a gap with a stick in its mouth and it won't stop trying even though the stick is wider than the Gap.
That’s the first and only dumb I’ll issue i assure you...
* I don’t know enough about electrickery to use that button anyway! Ha ha
Aye, well...so many Bad Spelling hits!
I wonder what prompted that?
Given there isn't any spelling error on my post...
Not that I give a Donald..but it would be interesting to know why...
Pirate please tell me you're joking lol
I was typing at the same time, I guess you've worked out why you got 5 bad spelling ratings.
All of this because someone got a dumb that was probably a result of an errant finger whilst scrolling the site on a phone.
Really???? FFS
I've had several dumbs which have not been explained, who cares. A lot of it is opinion so if someone thinks what you've said is dumb, so what??? There are more important things in life to worry about that getting a dumb on here, get over it and move on :D
As for removing the ratings, where do you stop with that... I don't like people disagreeing with me, can we get rid of that one too? Pretty soon all we'll end up with is positives... like, agree, friendly, winner... oh what fun that will be... never again will we get another thread because somewhat got a DUMB! :D :D
And the suggestion that a member be deleted because of it... LOL! Should maybe have given that a sarcastic optimistic rating :D
Wher’s my ban hammer :)
I found it @Sintra
Reminds me that I loved watching that first time around. Crockett is the only cop I know that quickly pokes his head around the corner to see if any baddies are there!
Just common sense in my eyes!
Reply to New consumer unit and partial rewire in Didcot, Oxfordshire in the Electricians Jobs area at ElectriciansForums.net
hello all...whats the typical cost for a new consumer unit fitted and the old wired fuse box removed im in a semi detached house in...
Hi, NAPIT report was carried out due to flood, all kitchen appliances, wall/light switches, fire/heaters etc need replacing. The electrician...
