shocking_eg
only use hager now.
although if cost isn't an issue.. merlin gerin seems the best
yes....and this is what the O/P should`v done before returning the item....at least that way he had the info available....should any salesman crap start to surface...I bought a BG garage unit and had the same problem took it back and the guy gave me a replacement out of his stock thats when I found the replacement was a better build quality as the test button was dark yellow and the garage RCD was bright yellow so its back to Wylex for me .
Also remember when you send it back it goes to the sales people who push the test button and say fine so when you send it back tell them to ramp,x1x5 test as well
and if you are still not sure change the CU out free of charge why because your reputation is on the line
and this one certainly wouldn`t hold up in a court either....should it go that way..when I worked in BMS systems the service guy tested the outstation alarm by initiating it on the PC but this did not prove the actual input at the outstation he thought it was smart I thought it was lazy now you think when you return the RCD they would have a calibrated tester on hand but I dont think plus the majority of these are built in the far east so that tells me their QC is not very good plus it would bother me if someone got hurt because I saved £15 on a CU
only use hager now.
