Discuss No earth wire on wall light? in the Lighting Forum area at ElectriciansForums.net
On my newly purchased wall light there is only a blue and brown wire and no earth. The connection from the wall however has brown, blue and an earth wire. My question is can I just cap the earth wire off and tuck into the light base? If so what is the safest way of doing this? Attached light and wall. Thanks in advance.
Reply to No earth wire on wall light? in the Lighting Forum area at ElectriciansForums.net
Hello, I’m trying to change a pendent light, I’ve wired it the same as the previous light that was on there however the light is now permanently...
Hi All, Would be grateful for some advice. Would like to add an additional light (Undercabinet 8W LED Batten light) to a two-way light switch...
Hello everyone, hope all are well. I'm changing a ceiling rose and have lost the diagram showing where everything was connected (to the old light)...
As the title says. But then I cut off a jst connection off one of the light strips and I can't get them to work together... the one strip is plug...
