B
bee-gin-errr
hi ladies and gents. were gettin some pretty major electrics done at the moment and i was having a look at the lighting circuits the electricians are putting in just out of bare faced curiosity. it appears that they have put little notches or nicks in the cable ends. were a few with 2 notches and even some with 3. are these used for some sort of identification or something?
Yes
These are identifying the swith wires, feeds,loop feeds etc so when they come back to 2nd fix they know what each cable is.
Every sparks seems to have a different way of marking cables and i've had to bell out an entire lighting rewire before connecting because someone else has wired it!
when I served my time as an apprentice I was told that the live and neutral had no nicks, live and switch wire one nick and any loop switch wire and neutral had two nicks when using T&E.
See what i mean thats 2 slightly different ways.
How about 3 cores for 2 ways and outside lights with permanant live to them
You could have a 3 gang switch by front door with strappers for up and down lights 2 ways, switch wire for down light and 3 core for outside light.
I would mark them;
Switch wire-one nick
down light strapper 3 nicks
up lights strapper 4 nicks
o/s light- a cross
I dont use 2 nicks for anything! Just the way i was taught when i was an apprentice:)
feeds have a diagonal cut
Switch wires have 1 nick on the side of the cable
strappers have a nick in middle of the cabel inbetween the 2 cores
Loop cables dont have any marks.
I just keep a permanent marker in my pocket. Loop cables have to labelling, switch cables and links to other lights on the same switch are labelled, that way no confusion.
Ooops! Typo, sorry, Loop cables have NO labelling!
labelling takes time and time is money my friend.
The worst is running data cables. I hated it, used to nick the cat5 with up to 15 nicks. Just to **** the data guys of
I go with Had8lives and just use the permanent marker
And all of these nicks, notches and croses have proved one thing, - there is no standard for this and you can definetely only rely on marks that you have put on the cable yourself! (or someone you KNOW is working to the same rules!)
Do they do a translation for the regs book?
i cant understand some of it in English so how do the imigrunts get on i wonder
hey dont knock the polskis i had a couple of north of the english border folk that couldnt mark cables ; i usually have to find out for myself despite what been marked ;
Half the time i cant remember what I marked thats why i use a permanent marker.......
notches
Talk Electrician Forum
Thread Tags
bee-gin-errr,
wayne,
