Discuss opinion on this wiring job in the UK Electrical Forum area at ElectriciansForums.net
Ok... ive recently completed 2330, so im no time served. However see the photo and give me your views, is this as incredibly dangerous and dodgy as I think...
I rent a house, my landlord is an electrician, supposedly JIB.
I went to test the element in my oven and couldnt find the isolator switch, realised the hob and oven are connected by a 13a plug each, both plugs wired badly with exposed cores, and the switch itself rests loosely on the cupboard shelf, which is then fed by a 1.5mm twin and earth??
The house isnt particularly impressive really as far as wiring goes...
An oven and a hob on a single 1.5mm.....
Thats just about the roughest thing ive ever heard of.
That cable will be massivley overloaded
On second thoughts.....
I guess its a gas hob right?
Still rough as assholes and 1.5 overloaded
He can't even wire a plug, what's the rest of his installs like?
Yeah that's pretty rough.
Again I'm assuming the plug on the right is for the ignition of a gas hob, and there isn't necessarily anything wrong with plugging them in in this way, but I really dislike the way the flexes just sort of disappear off through a hole in the cabinet - I would rather have the plugs and sockets behind the appliance so it's clear what they're for.
Also the socket should be fixed to something, preferably the fabric of the building, and I don't think I need to comment on the state of the wiring in those plugs.
Reply to opinion on this wiring job in the UK Electrical Forum area at ElectriciansForums.net
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
  • Locked
5K
I've moved house and have had a full re-wire and new kitchen fitted in Nov 2020, incl a new electric oven and gas hob. The oven is a Bosch...
12K
  • Locked
My cooker was wired to a 13a socket in the space behind the oven in a Persimmon new build, wooden construction. Some idiot cut the insulation back...
Hi all, Somebody wants a new electric hob installed to replace a gas hob Kitchen sockets are on the downstairs ring (small apartment) and a...
