Hi all,
I’m looking for some advice on installing an outdoor socket for charging my plug-in hybrid (BMW 330e), and wanted to sanity check the setup before going ahead.
Initially, I was planning to install a weatherproof outdoor socket (something like a BG IP66 double socket with built-in RCD) and use the standard BMW 3-pin charger. I don’t need a full EV charger as it’s only a plug-in hybrid.
I spoke to an electrician who suggested installing it as a spur from an existing socket, rather than running a dedicated circuit from the consumer unit.
The existing socket is on the same circuit as a washing machine.
My understanding is:
Any advice appreciated, thanks in advance.
- The charger will draw around 10–12A continuously for several hours
- The washing machine can draw around 8–10A when heating
- So together it could exceed 20A if both run at the same time
- Is a spur from an existing socket acceptable for this kind of use (plug-in hybrid charging)?
- Would the built-in RCD in the outdoor socket be sufficient, or should I be looking at RCBO protection at the consumer unit?
- Is there a real risk of overheating or long-term issues on a shared circuit, even if I’m careful with usage?
- Would you strongly recommend a dedicated circuit instead, or is that overkill for a PHEV?
