Discuss Outside Light Power Source in the Lighting Forum area at ElectriciansForums.net
from the socket use a bit of 2.5mm T/E to feed a Fused Spur Connection Unit, fused at 5A. then in 1.0mm to lights. use the FCU as a switch.
Put a long flex on the light, pass through hole in wall and put a plug on end of flex.
use 1.5mm 3core and you haven’t got to worry about what fuse is in the plug, although I would go for a 3A personally.
OK, do as my previous post. leave FCU switched on permanent. but can be switched off for maintenance. use a D/P FCU so a fault outside can easily be isolated.
Reply to Outside Light Power Source in the Lighting Forum area at ElectriciansForums.net
Hi all, I have a single switch in my garage to turn on a couple of lights in there. Yesterday I fitted a floodlight outside, drilled through...
Hello, I would liked to install a Byron wired doorbell with built in chime and 8v transformer. I'm struggling to get power source. I have a...
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
I made a DIY light fixture by putting some cut-to-size LED strips in an aluminum housing connecting them to a Mean Well DC power supply with a...
