Discuss Outside light wired in flex in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Outside light wired in 0.5mm flex but protected by a 3amp fuse. A 0.5mm flex max is 3A current carrying capacity, would you give that a code for an EICR? Cable size is small but it’s protected by the fuse, was thinking maybe a C3 due to it being a flex outside
Interested in this question - I've never found a reg saying you can't use flex outside, though am aware that fine-wire flex needs to be terminated in the right sort of accessory (e.g. cage terminals) or have ferrules fitted.
Is the flex designed for use outdoors and is is adequately and suitably supported?
Take that route and we're failing millions of miles worth of 6242Y hanging out of the wall before it enters into the bottom of the security light......
With modern floodlights, you have little choice but to use a flex outside - it comes attached to the fitting.
Whether it's acceptable or not depends on the type of flex. PVC flex would be coded or not for the same reasons as PVC T&E.
559.5.6 gives some guidance on that, along with the general principles of suitability
I normally screw a wishka box to the wall and then wire flex to the light
mush easier than trying to wire the light directly to the twin n earth poking out the wall
If I were to be doing first fix on this from scratch I'd probably be pulling H07 from the switch to the outside. Besides anything else, it's neater being black!
Reply to Outside light wired in flex in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Good Afternoon All Currently doing an EICR on common parts of a big site with multiple blocks. All blocks have outside garden spike lighting in...
Hi, Heavy industrial spark here, never do house bashing hence the question. I currently have a light switch at the front door not doing anything...
Hi all, I'm wondering if it's permitted to replace an outside wall light myself if I use the existing wiring from the old light. In theory I just...
What cable would you use to connect this light through a cavity wall to a FCU the other side of the wall? I am thinking, 1.5mm² 3 Core NYY-J...
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
