P
paulytrick
Hi,
I'm a in the 3rd year of my C&G 2330 electrical installation course and some time ago I completed a PAT testing course.
I haven't done any PAT testing yet - other than the small amount required on the course.
I have my first job coming up soon - a small engineering firm and I could use a little advice on testing 3 phase appliances.
Is it more or less the same as single phase 230v testing except I need to IR across all 3 phases and earth instead of the one phase and earth?
I've wired a couple of test leads to a couple of probes one on the CPC pin and one on the live so i can probe the plug pins to do the IR test.
Will this suffice or should I invest in an adaptor?
If so, How do the adaptors work? Do they put all 3 phases into the one single phase of the 3 pin plug for the IR test?
Also how long should I advise between tests?
I can't remember much of the course but I want to ensure I carry out all required tests fully.
Any help given would be very much appreciated.
Thanks,
Paul.
Thanks,
Paul.
