Discuss PAT tester recommendations wanted in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
W
WELSHTESTER
I'm in the process of setting up a new business venture specialising mainly in fixed wire testing, I've been a tester for the last 7 years now (electrician for 25 years), i'll also be offering to do PAT testing services.
I've not done much pat testing before so i'm keen to hear from you on advice on the best testers, easiest to use, most reliable and what are the minimum requirements that i'm likely to need (i.e...buy a tester with built in memory/software/printer/scanner...etc)
thanks in advance
Seaward prime tests are good...
If your just starting out you could buy the basic one and write the results out.
Then when your bored of doing it after 4 hours and want to jack it in. you haven't got that much to lose...
It depends on how much your doing and who for really. Seaward primetest are good basic units. Handheld battery powered. Can pick them up second hand for about £150 so not a massive outlay. Or if you do a hell of a lot of testing you could go for a seaward Europa or metrel omega, all singing all dancing, no paperwork, just pluginto PC after the job and click print!
If your just doing the very odd bits you might get away with using your MFT just make an adaptor and off you pop. If you've never done pat testing before then I'd suggest getting the 4th edition code of practice for hints and tips especially where PCs are concerned.
Good luck
Seaward prime test 200. Isn't a bad model, doesn't have a download software but you can test fixed appliances with them. I think the 300 model has software but not sure if it will test fixed appliances
Thread is 10 months old, I'd doubt he is still thinking about which one to purchase lol
Reply to PAT tester recommendations wanted in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
I've recently has an EICR (report attached) carried out on my two bed flat because I need to rent it out for a year. The electrician has come back...
I've got a 5 years experience along with.... 2365 l2 & l2 18th edition 2391 other stuff I won't bother listing. My question is since I'm...
NAPIT Certification Scheme Pat Tester and testing help please
Hi all, new to this forum and could do with some advice re Pat Testing. As the new law relating to EICR's to the private rented sector is coming...
Hi Everyone, I have recently bought a UNI-T PAT tester ( UT528) and have few questions: It is mentioned in the handbook, to limit the earth...
I have an SWA cable running from the CU to the garden that the previous owners had fitted, but no longer worked when I moved in a few years ago...
4K
