W
WELSHTESTER
I'm in the process of setting up a new business venture specialising mainly in fixed wire testing, I've been a tester for the last 7 years now (electrician for 25 years), i'll also be offering to do PAT testing services.
I've not done much pat testing before so i'm keen to hear from you on advice on the best testers, easiest to use, most reliable and what are the minimum requirements that i'm likely to need (i.e...buy a tester with built in memory/software/printer/scanner...etc)
thanks in advance
thanks in advance
