O
Old1
Anyone know how to test DMX leads (part of a disco lighting array) with a Seaward Europa Plus? Is there some sort of adaptor available?:whatchutalkingabout
While not strictly part of the PAT test procedure you could do a couple of tests - End to end continuity and a 50v IR test between cores
DMX cables are either 3 Pin or 5 Pin XLR. It's a Mic cable :) or as good as...
Should be wired pin to pin 1 being screen. you only need pin 1-3 wired in the 5 pin plugs.
Doesn't need PAT as the others said.
