Discuss Pendant light with no colour coded wires in the The Welcome Forum area at ElectriciansForums.net
No colours at all except the earth......I might be able to get a hold of a tester tomorrow, what would I be looking for? If I can't get a hold of a tester is there anything else I can do as keen to get the light up tomorrow as I'm not at home again until Christmas day and would like it up for then if possible
How about a photo of the other end where all the light goes on. Are you sure that's not a grey line on furthest left?
@Rpa07 Hows this ;)
I think you may have a live, neutral and earth in that transparent cable but gawd knows which is which. You're going to have to either take the fitting somewhere that can test it and mark the wires or you're going to have to get a sparky to come and test.
Please don't try it with guesswork, if you get it wrong there's a good chance you'll make the body of the fitting live and give someone a bad shock.
not really safe to assume anything for us as it's too hard to get a picture of what's going on. could be quite a few options! can you give the model of the fitting?
Reply to Pendant light with no colour coded wires in the The Welcome Forum area at ElectriciansForums.net
Hi all, DIY'er here looking for a bit of advice so please go easy on me. In my dining room there is an existing single pendant and i would like...
Wouldn't normally note this as an observation on a report but feel I need to. The way the building has been wired is all circuits on L1 have been...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi all, how easy is it to be able to shorten the drop tube of a semi flush light fitting ? Essentially what tools would I need for cutting the...
