C
chcnorris29
Hi,
Am soon to be getting a pickup truck for work use.
It will have a full canopy cover in the back (so the truck bed is covered, locked and same hight as the front cab of the truck).
The tailgate does not lock however the cover does lock and this prevents the tailgate opening when the cover is locked.
I plan to install a battery GSM alarm that not only will sound a loud alarm but also phone/text up to 3 people (me been one) to alert of any intruder in the truck.
Am wondering what everyone else has setup for security in pickup trucks and also how any of you who have a pickup truck for work have racked/organised your trucks.
I need things more common use (tools, steps, ect) closer to the doors and less used towards the back, but also secure and not going to roll round.
Thinking of using storage tubs or small plastic draws (if draws then strapped to the load points in the truck to prevent moving) to organise smaller material, and a small cable roller to hold drums of cable that i often use with less often use cable stacked up.
Not sure how best to secure tools. Not sure if to just put tool boxes in back of truck and strap them down to prevent moving or to rack the back some how to secure them, also looking at things like the DUHA tote boxes to secure tool boxes inside this, so it can be locked in place in the truck but removed when needed....
So may thoughts on how to set the back of the truck out.
Any of you got pics of how you set your truck out or ideas on how best to do so?
Thanks.
Thanks.
