Discuss PIR Limitations in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I
ICE
Phew its been a while since ive been on here (illness) Now I am well again and getting back to work I would like to ask some advice if I may?
When doing a PIR does anyone have a set list of limitations that they put on the form as I do not know how to word the limitations and what you guys put down as your usual limitations such as concealed cables.:angelsad2:
Thanks in advance
ICE
Hi ICE welcome back and hope things are improving for you mate.
Have a read of the notes in appendix 6 page 339 and reg 634.2 of the BRB and limitations is something you set up with the client and really is individual to each installation.
The one you highlighted is a good one for domestic installations and yes that would be a normal limitation on nearly every reports SoI
But others might be access to circuits or unable to find circuits. Access might be some circuits that are for production lines that just can not be switched off and so you are limited to what you can do if anything on them, and so you would arrange out of hours working or lim it.
Another common one is Ze, as it is often impossible to completely disconnect an earthing system from an installation safely. So you may do a Ze with it connected and compare notes if you have previous test records, or you will have started a base line level that other test in the future will allude to.
When I quoted for PIRs I did it by the circuit and often on big commercial/industrial sites I would put a time limitation on circuits, ie 30 mins, if I could not identify where/what/how a circuit was going then I would mark that down as a Lim. and either arrange a quote for tracing the circuit on remedial work or it was often as not left.
limitations as per standard list in bs7671(2008)
no Ze due to seals
no I.R. testing between live conductors of lighting circuit
live testing only of circuits affecting trade
no live testing of circuits above 2.5mtr in height
Thats a good idea, we have just completed one where we seemed to spend an hour or so on some circuits trying to find where it goes! Agreeing it as a limitation before hand for the time limit could be a cracking plan!
is it because they flap their flippers, wanting a fish?
so do i. can't see why mogga wants to pull the main fuse.
Reply to PIR Limitations in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
Hi All Happy new year to all! First post but long timer lurker, so thanks for all the previous help! Just wanted to clarify something I have...
