Search for tools and product advice,
Discuss Pot lights suddenly tripping breaker every time turned on in the UK Electrical Forum area at ElectriciansForums.net
mwhyte
Hi --
I have a series of 5 pot lights, 10-12 years old, in my kitchen, installed (not by me) when the kitchen was redone in 2010. Never had a problem with them, but now all of a sudden they trip the breaker every time I turn them on.
I replaced the halogens with LED bulbs almost 2 years ago and never really had a problem, though they would flicker a bit at low settings on the dimmer.
The pots are on a circuit with 5 other LFs, all single bulb. Shouldn't be anywhere near enough load to trip the breaker, and never has before.
I've done a bit of reading suggesting that it might be a load issue, but why now when it's never been a problem before? Would love any suggestions. Thanks!
It’s the breaker on the box in the basement that trips. Really bizarre, as we haven’t changed anything at all in years (except bulbs, and that was 2 years ago).
I’m guessing it’s some kind of short, but no idea where. When I take all the bulbs out, everything else on the circuit is fine.
Since the OP, I put all halogen bulbs back in to see if that made a difference. Nope. So it’s not the bulbs.
wondering if there’s something in one of the lights that’s causing it? Or the switch? Suppose I could try replacing the switch with a new one first to see if it makes a difference ...
A GFCI operates on low current fault to ground in milli-amps whereas a breaker operates on higher current in amps. Either way it sounds like a fault has developed.
and the lights all went out in Massachusetts.
maybe it could be solved by replacing the breaker? Do I need a GFCI breaker if there’s a GFCI outlet in the bathroom?
Hi --
It’s not a load issue, it’s a short circuit issue. If it was a load issue it wouldn’t trip immediately. Somewhere you have a wire going to ground. All I can tell you is open each light until you find your problem
Reply to Pot lights suddenly tripping breaker every time turned on in the UK Electrical Forum area at ElectriciansForums.net
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
Woke up this morning and tried to turn on the computer (work from home) wouldn't power on, checked lights they worked fine. Went downstairs to...
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
