Discuss Pricing in the UK Electrical Forum area at ElectriciansForums.net
H
Hawk
The house in question has all carpets lifted so easy access for running cables. So here's what I've done and to do. Materials were £500.
1. 17 spotlights wired and fitted.
2. 10 additional points in kitchen (sockets, fused spurs, cooker switch) walls chased, conduit installed and wired.
3. 10mm bonding to main water pipe. Approx. 25mtrs.
4. 15way dual rcd consumer unit fitted to replace two old fuse boxes.
5. Extend upstairs ring to include 3 extra sockets. (surface mounted)
6. Corrected landing light borrowed neutral. Was pretty handy to do.
7. All sockets and switches to be replaced throughout. (Approx. 20)
8. 4 new light fixtures to install. Already wired.
9. EIR
As I always seem to undercut myself, I'm hoping that you guys could give me an idea.
I've estimated 60hours to complete the job. Based in N.Ireland and the job is about 30 miles away
Cheers
I don't understand the need for the bullet point list when you've given us your estimated hours and the price of all materials ?
£500 + 15% markup.
60hours x hourly rate (or day rate if you do one)
I hope you mean EIC not EIR (EICR) ?
Then stick on a fuel cost - £30/40?
That's around the figure I came in with tel. But then I was thinking it was a bit steep as people say a rewire isn't a kick in the a#se off that price.
If the job was local [say within 10 minutes driving] I'd go with £1750 but as it's 30 miles away you'll be looking at an extra hour each day minimum just for travelling so even doing that very cheaply I'd add on £100 for that, there's a fine line between making what you're worth and being undercut by someone maybe a bit less fussy though...
Reply to Pricing in the UK Electrical Forum area at ElectriciansForums.net
Hi all! Posted on here a couple of years ago and got great advice. Have been self employed a couple of years now and always find pricing work the...
This weekend I was replacing a hall light fixture in my old home (rewired circa 1980/90's) and noticed the work was done using one of the exposed...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
Hi, I have recently moved house and what to replace the garden shed. The shed has some electrics; a double socket with a fused light switch and a...
