B
brucelee
Hi mate think the new C&G qual your referring to is what they now have decided is needed for someone such as yourself to register with one of the governing bodies
Its fairly new so I dont know much about it up until recently you only needed the 2382-12 to register with a governing body to carry out work in domestic properties which was nowhere near enough as its basically a qual that taches you how to read the regs
a testing qual would help but as others have said
College is the only route if you want to be a fully qualified electrician at some point and would include a NVQ lv3 if you ever want to be registered with JIB as a electrician
Have you visited the C&G website and looked the qualification number up this should tell you more about it
What is the name of the course provider who is delivering this qual
I think there is also a EAL qualification you can do but C&G are jsut about more respected but they change the numbers of the quals like the wind
good luck mate its not easy but if you persist you will achieve
