Discuss Quality of work in new builds in the UK Electrical Forum area at ElectriciansForums.net
Better than what I have seen, SWA floating in the meter box with just a tenby earth clamp round the armouring and earth lead ran off.
It still just does not feel right, I like to see these terminated into a full inclosure, switchfuse A+
Ive read here quite a few times recommending using a similar bracket in just such an instance. I don’t think a metal switch fuse, would fit in that gap, unless the supply isolator was moved? Perhaps the DNO claimed their ground. Incidentally why a swa?
How far is it from the meter box to the consumer unit?
in feet. sod foreign centipedes.
I’ve been thinking about this one all day, and agree with Creep.... sorry Radiohead.... it’s in an enclosure.
Rough as a badgers ar*e though.
It reminds me of a pv installation in a house I was in. 25mm tails from Henley block, into a DP isolator enclosure..... nothing strange there.... but it came out in 10mm t&e to go to the pv meter.... basic insulation showing.
There is a relatively new build estate (built around the Late 2000s) very near where I live that uses 16mm twin and earth for its submains.
basic insulation is on show in every meter box.
so perhaps the meter box is classed as an in closure thus negating the need for containment of cores.
they also got away with no rcd protection on the submains as it was around the same time as rcd protection on everything were just coming out so wired the cable directly into the meters and didn’t bother to Rcd protect it...
Reply to Quality of work in new builds in the UK Electrical Forum area at ElectriciansForums.net
Good morning all, long time reader first time post so looking for some help I’m qualified as an electrician but haven’t worked as a sparky for...
Hello, I’ve got an issue driving me crazy and can’t get anyone to figure it out as it’s not their issue. We had a new extension, single rear...
This drives me round the twist, the client tells you what they want, kind of. you do the work the way the client asks you to and then when its all...
