J
James1234
An electrician noticed that the clamp on the earth wire in my house wasn't right while he was fixing an unrelated fault. He called the power company because they have a legal duty to fix it. I noticed that the guys from the power company have used tape instead of a clamp and wondered if this is acceptable?
Thanks.
Also....get that earthing conductor checked pronto! Earth fault current will be unsure where to go and won't know it is allowed to flow through it as it's splendid green/yellow markings have been painted over in emulsion.
They use a special sprung clamp now that won't loosen if the lead creeps and also doesn't cause any unnecessary lead exposure to the jointers. We had the same done and the earth was a lot better afterwards.
A cv spring.
Does that comply?
Don't actually know but are supplied in some jointing kits. I don't reckon there is one under there it is too bulky on one side. Wouldn't mind a pic from a couple of other angles.
Could the bulk be where the braid has been folded over to prevent it from being pulled out?
