Creda Starlight replaced 7" radiant ring with 5 turn version which trips at RCD. Tried with 2 new rings , same result.
Replaced with 7" radiant ring with 4 turn version which works perfectly.
What is explanation for this .
Rcd will only trip if there is a leakage to earth.
what is the insulation resistance of the element? if you dont have equipment to measure it then i am afraid that calling in a professional is your only option.
