should bring back the old 15A round pin sockets. you could squeeze loads of flexes in them, wedged in with the only plug you need.
The 15A round pin, real-mans sockets are standard here, usually on 20A radial circuits so the chances of acute overloading isn't high. Much better not having to faff around with fuses :)
There's lots of advantages to the round pin plugs, they don't hurt as much when you accidentally stand on one for starters.
**edit** incidentally the round pin sockets are generally considered to be 16A sockets as opposed to 125A mentioned above. Not sure why....
I think when the original plugs were designed they did not apply a lot of technology to them, "hmm this does not get hot, must be OK with that load"
I seem to remember that there was some discussion about the 5A plugs and the powers that be saying well they can take 10A anyway, so presumably the 15A socket could actually take about 20A and so a rating of the now "standard" 16A makes more sense.
It's great that they are advertising this public safety notice. Most fires start due to portable heaters + other appliances overloading the extension, this needs to be advertised through until winter and get the message across.
