Discuss Radio interference from LED lamps in the UK Electrical Forum area at ElectriciansForums.net
Just replaced some kitchen light fittings with fittings that have GU10 led lamps, now when the lights are on and they are listening to Radio 4 the radio crackles! Radio is about 2 meters from lights! No dimmer involved.
Any ideas on how to fix. Just going to email Ledhut as well as that is were I got them!
see if radio 4 has an alternative frequency.
It maybe down to cheapo components or lack of filters in the lamps themselves as we have a couple of led candle lamps that interfere with the baby listener also retro fitted a led reverse lamp on the wife's car and there's interference on the fm channels when reverse gear is selected.
Switch not changed. Would it make a difference when changing from standard tungsten lamps to LED?
Just thinking that with a resistive joint, of dirty contacts at the switch arcing on each switch on, the higher current of the tungsten lamps may just burn through it but the lower current with LED is struggling to keep it clean.
A bit vague perhaps and just a thought about where you could get arcing which will readily cause interference.
It is harder to get arcing at a PC board but you can get specific frequency faults with the rectifier as stantheman said.
Is this digital radio? I've read about issues with cheaper LED lamps causing electromagnetic interference, apparently they don’t have the required shielding. Not sure if this is related to your issue.
Reply to Radio interference from LED lamps in the UK Electrical Forum area at ElectriciansForums.net
I have a street light circuit on land I rent out. I need to replace 2 of the bulbs. 1 of them is an old Philips 55W SOX Plus, the other is a...
Morning All Got little bit situation going on, causing multiple visits (luckily only 2 mins drive from where we are.) Client not 100% happy with...
Done a job yesterday, remove old 12v halogens and replace with mains, gu10 downlights. Fitted some LED gu10's no issues. Got a call today saying...
Hello I have some decking lights which to be fair, have been nothing but pain in the bottom since they were installed. Moisture in the lens lamps...
I really need help with this puzzler. First - I am moderately 'skilled' in day-to-day basic wiring. My puzzle: I am trying to replace a...
