Discuss RCB or RCBO in a Distribution Board. in the UK Electrical Forum area at ElectriciansForums.net
Andy C
I am getting back into the electrical game after a few years and wondered what peoples thoughts are on the above.
I am happy installing fully RCD protected DBs or Split boards but the use of RCBOs I had never seen. What are the main reasons/advantages/disadvantages for using them? I know they are wired differently within the DB.
Sorry if it seems a daft question.
Thanks for any replies.
RCBO's in the event of a fault will only trip the circuit at fault where as with a dual RCD board or Upfront RCD you could potentially loose half or all you circuits.
Thanks Lees, I get that and was aware, but is it just a general trend towards say rewires now to use RCBOs as standard and move away from split boards or dual RCDs.
Thanks for replying
what he said ^^^^^. the advantage of RCBOs is that a trip will only resultin the loss of the circuit with the fault.
dsadvantages are:
1.cost
2. a trip may be due to either an earth leakage or an overload. a bit more tech. involved than with separate MCB and RCD.
There are RCBO boards that don't cost too much more than Dual RCD boards .... so offer the client the choice.... the pro's of an RCBO board far outweigh the con's of a dual RCD board IMHO.
Also if you have an existing board with, say 4 circuits a dual RCD board doesn't make sense...
Also provides complete division of circuits if rcbos are employed, eg. a fault on one circuit, theoretically will not affect another.
just need to get your head around those 30ft long coiled N tails that will not ever sit where you want them to.
Just plucking prices off the internet, typical budget board with 2 x RCD and 10 MCB = £66. Same manufacturer 10 x RCBO's alone = £190. Local wholesaler complete board with 2 x RCD plus 8 MCB = £65 plus VAT, similar board with main switch and 8 RCBBO's = £136 plus VAT. It is obvious that, electrically, having discreet devices is better, but does the customer care? Around my way there is almost a "standard" price for a board change, and using RCBO's is going to cut into the profit margin too much, or just mean the job will go elsewhere. I have to say I have had a dual RCD board in my own house for a good few years, never been any problems with associated circuits being taken out on the rare occasion an RCD trips. The "pro's" are fine, but the "cons", in most customers eyes outweigh them by way of not getting the job!
Thanks for the replies guys. When I last did electrics it was all RCD and Split boards. There are so many changes. It looks like I have a steep learning curve over the next few months, but looking forward to getting back to working with my hands.
Testing..... Whats that all about... Thats going to burn up a few of my remaining brain cells...
Thanks again
Best you do some reading or else installing RCD CU's could turn into an unmitigated nightmare for you!
Oh, and the icing on the cake is compliance with Part P - so scheme membership and all that entails!
Thanks Murdoch.
Practically speaking I will be okay as I did a full apprenticeship in the 80s and have all the knowledge and experience in fitting etc. There will be a few bits such as the shortening and crimping of RCBO cables ghat are different.
I am taking the 17th edition and 2394 and 5 in February so hopefully fingers crossed i will obtain passes. I am looking forward to working with my hands again. I am thinking of asking a small contractor if a could shadow them when testing to give me more of an idea, maybe for a cheap day rate for them as an incentive.
As i would be doing mainly domestic I was going to join STROMA
Any ideas or suggestions would be welcome.
Thanks Murdoch.
I was referring the testing...... not the fitting.
You know you have to complete an EIC with a CU change?
Thanks Murdoch.
If you're fairly tall that would be ideal for helping with bits he couldn't reach very well. :D
Thanks Murdoch.
All Little & Large jokes aside, you want to rethink your business venture. I did something similar, and have to say it's been quite hard getting constant flow of work. I'm told it can take 3-5 years to build up a business profile, with contacts etc. It's also a steep learning curve, coming back into the industry after so many years. I'd either forgotten things, all things had changed, certainly inspection, testing & certification.
Once you've done your courses, if you could work alongside another electrician or contractor, that might prove valuable.
We don't stick green/yellow wires on every bit of stationary metalwork anymore.
I remember those days, if it didn't move, earth it.......
I am looking forward to it but i think the bureaucracy may drive me a bit mad i think.
Another little request a good crimping set that will deal with cables up to 16mm in case i have to crimp those. otherwise it will be the standard domestic cable types.
Cheers, every reply appreciated.
I am going to ask an unknown to me but prospective (to do the work on my house) electrician whether RCBO's alone (plus main switch, of course) can be used on a replacement all-RCBO CU in place of the existing and very old fuse-type Bakelit CU in my Victorian house. It would be nice to know beforehand whether he knows what he is talking about in terms of whether my installation is TT, TNS or TNCS as I, in my very limited capacity as a general builder, understand that RCBO's Type B are not the solution for all domestic earthing arrangements.
So, how can I find out whether I have a TT, TNS or TNCS arrangement?
Advice greatly appreciated.
Joe B
Joe B
Best to start your own thread
Reply to RCB or RCBO in a Distribution Board. in the UK Electrical Forum area at ElectriciansForums.net
For context i am in my 2nd year in college and my head is going round in circles a question in my project for which i need to select the right...
4K
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
Need to source Type B 3-phase distribution & 3P MCBs for EVSE, 1P RCBOs etc. so my sparky can install. A 6-way 3P board will suffice. Wondering...
Hello, I have a hypothetical question (I'm an electrical engineer) to better understand RCBOs and how they are used in the USA. Let's say I would...
We might need to have a small 3-phase DB in an industrial location that might be exposed to the elements occasionally, though normally it will be...
