If for example its a lighting circuit I would go to end of line and carry out earth loop test, and following that I would do RCD test at same place. 1/2 current test 1st which shouldnt trip RCD, then 1x current, then 5x current. I understand the 0 and 180 methods as it accounts for both sides of the AC waveform, but to be honest its not something ive ever done and I would guess a lot would say the same.
you are right with the half, times one and times 5 tests, and the 0 and 180 degrees should be carried out, for a 30 ma RCD what readings would the times one and times 5 need to be under to pass? and why test at furthest point?
Feel like im being interregated here! I reckon you were hoping I missed the 1/2 current so you could catch me out! For 1x current less that 200mS 5x current less than 40mS. Ive always done test at end of line because thats how i was shown years ago and have carried on since, no other reason
I'm only trying to get you to think, A merry christmas to you and I am being friendly, all the best bud, as you have now answered all the questions go back to your first post and think did I need to ask the question, looks like you know after all whats involved doesn't it? oh by the way, just for clarity, no need to test at the furthest point, I like to test at the RCD myself. Welcome to EF fella.
Mike
Ok great stuff, I just thought end of line would ensure whole circuit would operate but I suppose Earth loop test would prove this anyway, cheers, having other opinions certainly helps the thinking process! merry christmas too.
yeah cheers, I will enjoy a week with the family, now you know 200ms is the reading to try to get under and your test showed 320 you know about the RCD concerned, I think your a pretty good kid and just lacks a bit of confidence, you know your stuff, get confident, sounds like your a decent guy. regarding the ZS this is a different matter, out of interest do you know the maximum for the RCD to work within the required time? No matter if not, just a last homework question.
Mike
Mike
300ms for BSEN
200ms for BS
