Discuss RCD Keeps Trpping in the UK Electrical Forum area at ElectriciansForums.net
W
westfielder
Dear all,
The consumer unit main RCD (80A, 30mA)keeps tripping. We've noticed it when my stepson plugs in a laptop on the upstairs ring main and also randomly when nothing else is in use (eg at night) and we suspect it's the fridge freezer turning on and off. (downstairs ring main) or when SWMBO has turned on another appliance.
The individual breakers don't change.
To reset, we have to switch off all the individual breakers then switch on the main RCD and then switch on all the individual ones one by one.
We have solar PV
Do RCDs wear out or become sensitive?
Anythiong I should do before getting an electrician in
Many thanks in advance
Nick
Dear all,
We have solar PV
Nick
Nope just call a electricain. Would you fiddle with your gas boiler if it was faulty
unless you have a test kit and know what your doing your best to call in an expert
as you say it could possibly be an appliance but there is no way of telling without seeing it and c arrying out appropriate test!!
Just disconnect the earths in the board,it won't trip then!!!
Call someone in,for what you'll spend messing about cluelessly randomly replacing parts at least they'll get to the root cause of the problem,which I suspect is a faulty item
Or RCD
Or general wiring issue
Or an earthing strap loose onto the incoming supply.
Anyone like to add?
RCD'S don't become sensitive, they're born sensitive. Earth leakage is a cumulative problem. Lots of small amounts of leakage in several appliances or circuits are seen as a cumulative result by the RCD. You need special test equipment to test the RCD unit and also to find the earth leakage faults. At best all you can do yourself is unplug appliances and see if the problem stops, thereby localising the problem. Even then it's pretty doubtful you could fix it yourself unless it's an obvious problem like a damaged cable or something getting wet for example. I'd recommend you find a well respected local electrician.
Reply to RCD Keeps Trpping in the UK Electrical Forum area at ElectriciansForums.net
Hi, I swapped a 2 gang switched socket for a 2 gang switchless socket with usb ports downstairs. I switched off all the power to the house by...
Hi, I moved home a few months ago and the electrics RCD keep tripping. Sometimes it will happen every few days and sometimes will be fine for a...
7K
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
