Discuss RCD protection in garage in the UK Electrical Forum area at ElectriciansForums.net
If I have a distribution circuit (to a garage with accommodation upstairs) does the CU in the garage have to have RCD protection or is it sufficient for the main CU in the house that feeds the garage to have RCD protection? Just wondering about regulation 411.3.3 additional protection as there will be sockets and a shower in the garage.
Thanks for any replies
D2E
It could be either.
Have a little think about why we need rcd protection and not just for sockets etc.
It can depend on the installation method.
Sent from my iPhone using Tapatalk
Is the garage a TT conversion if so all circuits will require RCD protection.
One question what sort of loading will the garage have a shower sockets and lighting may be a bit too much to supply from a spare way in the main CU.
All circuits in a room containing a bath or shower require additional protection.
D2E
You say accommodation upstairs. Is it for a member of your family or a lodger/rental? If so, they will not want to be knocking on your door to reset an RCD.
Reply to RCD protection in garage in the UK Electrical Forum area at ElectriciansForums.net
hi all come across a new build commercial office where radial circuits feeding electrak power track was protected by 32A RCBO at dist board and...
Hi, if getting back to the CU is not an option, instead of spurring off a socket via a Sfs putting the rating down to 13a. Could you spur off the...
Hi all, Merry Christmas to everyone, and apologies for talking work during the holidays😅 I have my first EV charger install job early in the New...
HI folks, I'm on the management committee of the block of flats where I live. We've got ancient garage electrics and want to rewire. I have a...
