Discuss RCD Spur in the UK Electrical Forum area at ElectriciansForums.net
malc. i'm doing kev's thursday/friday. got all the kit except for the CU. getting that wednedsday.
no probs. my son is going to be with me, doing any heavy work.
how come every single new static caravan that comes off the shelve has a 1gang unswitched socket next to it in the broom cupbord and a bit of flex hanging down with a 3pin socket on the end then.? gassafe must state then that removing the plug is adequate as safe isolation.
Reply to RCD Spur in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, I have been asked to pull in some new 3 phase supplies for 7 new welders which do not require a neutral connection. The client has...
Hi all, I am at odds on whether RCD protection is required on an SWA of 14 metres, clipped direct under flooring direct from CU to an exterior...
Hi Guys, Long time member and not a regular user here. I do pop in here when the odd unknown pop's up and unable to locate an electrical dilemma...
Called out to fault on RCD tripping maybe twice in a month for sometime. Did all the tests & found RCD was faulty, Refitted a new Rcd Type A which...
Hi all, Just a quick one regarding the need for RCD protection for socket outlets rated up to and including 32A. I have been tasked to install...
