M
markthespark
Hello all, while i was away, the RCD kept tripping intermitantly at the house which my mum rents out, so the letting agent got their electrician to go round and he couldnt find the fault so he changed the RCD for a main switch as a temp measure.
When i got back i went round and installed 2 waterproof boxes on 2 cables that were outside that could have been exposed to water and i also changed the main switch back to the RCD. Turned it on and it was fine so i thought it was job done.
This was around a week ago, just recieved a phone call this morning to say it has tripped again, so i told her to turn all the breakers off and turn them on 1 by 1 to locate the circuit where the fault is. However its tripping the RCD when both 6A Lighting MCB is switched on and also 32A ring main MCB is switched on. She also mentioned that it tripped when her son tried to use the Electric shower, which is on a separate 32A breaker.
Anyone got any idea what it could be?
Im thinking faulty RCD maybe?
Many thanks.
Many thanks.
